Motion in Two or Three Dimensions
  • Thread starter Thread starter CodyBr
    Dimensions Motion
The discussion revolves around calculating the displacement, average velocity, and average acceleration of a bicyclist moving between two points relative to a flagpole. The initial position is 26.0 m east and the final position is 26.0 m north, leading to a displacement magnitude of approximately 36.8 m and a direction of 45 degrees. The average velocity is calculated as 1.05 m/s, but there is uncertainty regarding its direction and the calculation of average acceleration. Participants suggest using a Cartesian coordinate system to clarify the trajectory and motion. The overall challenge lies in understanding the transition from moving south to north while heading east, which may imply circular motion.
CodyBr
At one instant a bicyclist is 26.0 m due east of a park's flagpole, going due south with a speed of 14.0 m/s. Then 35.0 s later, the cyclist is 26.0 m due north of the flagpole, going due east with a speed of 14.0 m/s. For the cyclist in this 35.0 s interval, what are the (a) magnitude and (b) direction of the displacement, the (c) magnitude and (d) direction of the average velocity, and the (e) magnitude and (f) direction of the average acceleration? (Give all directions as positive angles relative to due east, where positive is measured going counterclockwise.)
I honestly don't know where to begin. Would the magnitude =sq rt. (26^2+26^2)?
Any help would be greatly appreciated.
yes, but what is the reasoning.
Try to develop the coordinate system, e.g. 26 m due E is what in a Cartesian system, and 26 m due N is what? Assume the flagpole is the center (origin) of the coordinate system.
If one is E going due S, and N going due E, what trajectory does that describe if acceleration is constant?
Hint -
I'd say that 26m due E just (26,0) and 26m due N is (0,26). That I get, but being at (26,0) heading South and then 35sec later being at (0,26) heading East doesn't make a lot of sense to me. Trajectory would be SE?
The reasoning behind the magnitude is that the position changed from (26,0) to (0,26). and the distance between them is the square root of their sums squared.
Think about traveling clockwise. If one is initially traveling south, how does one end up north traveling east?
Traveling in a circle.
(a) I get 36.8m
(b) I thought would be 45 since the arctan of (26/26) = 45?
(c)1.05 m/s
(d) I'm not sure how to go about calculating it.
(e) Divide avg velocity by 35 sec?
(f) 45 degrees?
