How Do You Calculate Friction Force in a Two-Mass System?
  • Thread starter Thread starter -EquinoX-
To calculate the friction force (fk) in a two-mass system, the equation derived is fk = m(a + g) - Ma, where m is the mass of the hanging block and M is the mass on the plane. The discussion highlights the importance of correctly defining the positive and negative directions for acceleration (a) to ensure accurate results. There is a suggestion that the expression for tension (T) may be incorrect, potentially due to misinterpretation of direction conventions. Clarifying the direction of acceleration is crucial for solving the problem accurately. Understanding these dynamics is essential for correctly applying Newton's laws in this context.
-EquinoX-
http://img406.imageshack.us/img406/6092/testdd5.th.jpg http://g.imageshack.us/thpix.php
find the fk in terms of M,m,a
So what I got in the end result after decomposing the forces on each object and then do a substitution is :
fk = m(a+g) - Ma,
where m is the mass of the hanging block and M is the mass of the object in the plane. Is this wrong?
I think your expression for T is incorrect. It may have to do with defining + and - directions.
In your +/- convention: if "a" is positive, do the blocks accelerate to the left & up, or to the right & down?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
