Where Does the Energy Go in an Electric High Pressure Water Motor or Pump?
In an electric high-pressure water motor or pump, the main causes of energy loss are primarily heat and electrical losses in the motor, along with friction in the pipes. The efficiency of the motor, whether it is oversized or undersized, significantly impacts energy loss, as do flow rates and the length of pipe runs. Most common pressure washers utilize positive displacement pumps, where the largest energy loss typically occurs in creating the differential pressure. Comparisons of electrical input and output can help quantify these losses. Overall, while fluid losses are minimal due to low flow rates, motor efficiency remains a critical factor in energy loss.
Patrick Jago
In an electrical high pressure water motor or pump what is the main cause of energy loss.
Originally I was thinking along the lines of
1st heat/electrical losses in motor.
2nd Friction of the water in pipes.
3rd noise. But I'm torn between the first 2 ? Tho
  1. :welcome:
How could there be a universal answer?
  1. The Motor can be over /under sized, or high /low efficiency.
  2. High or low flow rates.
  3. Long or short pipe runs.
  4. Losses measured at the pump outlet or at the pipe ends.
Agreed
Although this question in particular is concerning a pressure washer.
Patrick Jago said:
Agreed
Have you done any comparison yet of electrical input and PV output? to obtain for a quantitative value for the loss.
Most common pressure washers are simple positive displacement pumps with pistons, check valves used to control flow into and out of the cylinders. If that's what you're talking about then the biggest loss is usually creating the differential pressure. After that I would suspect it's losses in the drive motor. Fluid losses are probably minimal since flow rates are relatively low.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
