Mousetrap Racer - Applied Forces
  • Thread starter Thread starter TheScienceKid
    Applied Forces
To test Newton's Second Law by varying the force on a mousetrap racer, one approach is to modify the applied force through the use of a spring, which requires measuring the spring constant. The discussion also highlights the importance of understanding how forces like friction affect the racer, although gravity cannot be altered. An example provided involves stopping a 50kg car moving at 4 meters per second, which would require a force of 100N to halt. The focus remains on how to effectively manipulate and measure the forces acting on the racer to observe their effects on motion. Overall, the conversation emphasizes practical methods for applying Newton's laws in a controlled experiment.
TheScienceKid
"Suggest a way of testing Newton’s Law by altering the force applied to your mousetrap racer."
Basically, what the question is asking for is a suggestion for a way of testing Newton’s 2nd law by varying the force on the racer.
Now, I've already tested Newton’s 2nd law by varying the mass.
But when it asks me to vary the force on the car, what does that mean exactly?
Would it be something like this:
The car has a mass of 50kg. I stop it while it is moving initially at 4 meters per second. The force applied to that would be 100N.
Or something about varying gravity and friction, since they are forces acting on the car?
Well you can't vary gravity. One way to modify the forces acting on the car is to attach a spring to it (you'll need to measure the spring constant).
Thread 'Calculation of Tensile Forces in Piston-Type Water-Lifting Devices at Elevated Locations'
Figure 1 Overall Structure Diagram Figure 2: Top view of the piston when it is cylindrical A circular opening is created at a height of 5 meters above the water surface. Inside this opening is a sleeve-type piston with a cross-sectional area of 1 square meter. The piston is pulled to the right at a constant speed. The pulling force is(Figure 2): F = ρshg = 1000 × 1 × 5 × 10 = 50,000 N. Figure 3: Modifying the structure to incorporate a fixed internal piston When I modify the piston...
