Move 'dx' from 'dy/dx' to the other side, then integrate both sides
  • Thread starter Thread starter knghcm
    Dx Integrate
The discussion revolves around the manipulation of the derivative notation dy/dx, specifically moving the dx term to the other side of the equation and integrating both sides. This is situated within the context of differential equations, which the original poster (OP) is encountering in their engineering studies.
  • Mixed
  • The OP expresses confusion about the technique of manipulating dy/dx and seeks clarification on its validity and underlying principles. Some participants question the mathematical rigor of this approach, while others defend it by referencing differential forms and change of variables. The OP also inquires about resources for learning more about separable differential equations.
Participants are exploring different perspectives on the mathematical validity of the technique discussed. The OP has identified the topic as separable equations and is seeking further resources to understand it better. Guidance has been offered regarding textbooks and general strategies for approaching the study of differential equations.
The OP mentions a lack of formal education in differential equations, which may influence their understanding of the topic. There is also a reference to the complexity of hyperreal numbers, which some participants suggest is not necessary for the OP's current needs.
knghcm
I've been reading in my engineering textbooks and came across a frequent equation manipulation that involves multiplying/bringing the dx term of dy/dx to the other side of the equation, and then integrate both sides. I don't know what technique this is and I can't find it in my Stewart's Calculus either. Please help me find out what this is and how I can read about it more. I've heard that the individual dy and dx terms are called infinitesimals but when I googled infinitesimal calculus, the results all went way over my head (wtf is hyperreal?)
I really need your help because I'm starting to get lost on the math on my engineering classes. Thank you.
Edit: okay I've just done some googling and it turned out to be a simple differential equation problem. Since I have not taken any differential equation yet, what is a good way to quickly gain ground on this topic so that it could be useful for other classes while not getting bogged down so much that it's like another class of its own.
It is an example of bad mathematics: It works for engineering/physics equations, but it is not a proper way to handle derivatives.
It's not an example of bad mathematics... There is a formal theory of differential forms, and bringing the dx to the other side is just simply used to express a relation between the differentials... Of course, without resorting to differentials, you can just interpret it as a change of variable, but that's not necessarily any simpler...
To the OP: You don't need to know anything about hyperreals :) That's just a separable differential equation. Every class of differential equations has its tricks ;)
If your equation is of the form: f(y)\frac{dy}{dx}=g(x), just integrate both sides and use a change of variables to obtain an implicit expression for y:
f(y)\frac{dy}{dx}=g(x) \Rightarrow \int_{x_0}^xf(y)\frac{dy}{dx}dx=\int_{x_0}^xg(x)dx\Rightarrow \int_{y_0}^yf(y)dy=\int_{x_0}^xg(x)dx
(Technically, the variable of integration can not simultaneously be its upper limit, but just switch the y's and x's inside the integrals to y' and x' or something, to distinguish them from the limits)
Thank you so much for your answers. Bad mathematics or not, where I can go to to learn more about this technique? It's coming up a lot in many engineering "proofs" I've come across so I need to know it pretty well.
Edit: I just picked up the Boyce and DiPrima ODE book from my college library, and they are called separable equations (section 2.2 in the 9th edition). I will definitely spend much time on this. If there's any other resources that I need to be aware of please let me know.
I don't know anything about that particular book, but any introductory ODE textbook should suit you fine. There's not really that much to know about separable equations, just a couple of tricks to recognize if a certain equation can be made separable under a certain substitution, or rearranging the terms, etc. Other than that, it's just integrating both sides ;)
Also very common and of utmost importance are linear differential equations, and there's also a simple trick you can use to solve them. Another large class of ODEs are exact equations, or ones that can be reduced to exact. Depending on your needs, you may need to solve systems of linear differential equations, or differential equations with higher order derivatives. It's an interesting subject, just pick up a book and read, or maybe watch MIT's lecture series, although he starts off by mentioning that he expects students to already know how to solve separable equations ;)
