How Much Energy Does It Take to Move a Submarine Through Water?
  • Thread starter Thread starter Stevethesub
    Mass Water
Building a submarine requires understanding the energy needed to move it through water, which is not equal to the energy required to displace the same volume of water. The energy needed depends on the submarine's mass, the distance traveled, and the friction from water's viscosity, which increases with speed. The work done can be calculated using the formula: work = force applied * distance traveled, where force includes overcoming viscous drag. Additionally, buoyancy and design principles similar to those of airplanes must be considered for effective operation. Homemade submarines pose significant risks, highlighting the importance of safety in design and operation.
Stevethesub
I am planning building a sub. I am tring to find the amount of energy it takes to move it.
I think it should be equal to the energy needed to move the same volume of water.
For example say the sub had the volume of 10,000 cubis feet.
1. Is my assumptin right?
2. what formulas are ther for this?
3. Is more energy needed at deeper depth? Why?
If You have Ideas post thanks
Welcome to PF.
1.) No. Consider a case where you move a ball through air. Does it take the same energy it takes to move the same volume of air? No! The same way, the work to be done depends on it's mass and how far you want to move it.Work. But the force applied depends on the friction of the medium. Since viscosity of water is more than that of air, more force is needed. The viscous drag increases with velocity so more the speed, more force to apply. Ultimately the increased force means increased work to be done.
2.) work done=force applied*distance travelled. And the force applied includes the force you need to overcome the viscous drag.Work
3.)You will also have to consider one more important factor, http://en.wikipedia.org/wiki/Buoyancy
And these might help you:Archimedes principle applied to subs
Principle of operation of sub
Think of the case of an airplane. Aerodynamic principles must be taken into account to optimize design.
Homeade subs are extremely dangerous and a great way to die. Do you intend this to be flooded (and you wear scuba gear) or filled with air for you to breathe?
OMG :bugeye: I thought about somthn like this
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
Thread 'Where is my curb stop?'
My water meter is submerged under water for about 95% of the year. Today I took a photograph of the inside of my water meter box because today is one of the rare days that my water meter is not submerged in water. Here is the photograph that I took of my water meter with the cover on: Here is a photograph I took of my water meter with the cover off: I edited the photograph to draw a red circle around a knob on my water meter. Is that knob that I drew a red circle around my meter...
