Moving about, velocity, speed, of objects
  • Thread starter Thread starter Chops0
    Speed Velocity
A train is moving at a constant speed of 20 m/s when its last carriage is released, which then comes to a rest after traveling 200 meters. The acceleration of the carriage was calculated using the equation v^2 = u^2 + 2ar, and the time taken to stop was found using v = u + at. To determine how far ahead the train was when the carriage stopped, the distance traveled by the train during the time it took the carriage to stop was calculated. The final result showed that the train was 200 meters ahead of the carriage when it came to rest. The discussion highlights the application of kinematic equations to solve motion problems.
Chops0
i have this killllerrr question i need some help on. idno what to do..
A train is moving at a constant speed of 20ms per second along a striahgt, level track when its last carriage is released. This carriage comes to a rest after continuing for 200m along the track. the speed of the train remains constant.
a.) what was the acceleration of the carriage.
b.) how long did it take for the carriage to come to a rest?
c.) how far ahead of the carriage was the train when the carriage stoped?
i got the first 2, using v^2 = u^2 + 2ar, and v = u + at
idno how to get the last answer.
no idea.
Find the distance traveled by the carriage after it got disengaged from the train. Also find the distance traveled by the train during the same period of time. See what to do next?
how do i know when it got disengaged?
cos it just says the carriage got disengaged from a train goin 20msper second :S
no wait!
hahah i got it man
thanks bud
what i did was
r = ut + 1/2at^2
because i got the time from part B
turned out to be 200metres ahead :D
thanks man
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
