Solving Differential Equation: Boy & Girl's Meeting Time
The discussion focuses on a problem involving a boy on a boat and a girl running along the shore, requiring the determination of their meeting time using differential equations. The boy's movement is modeled in polar coordinates, leading to a set of differential equations derived from the boat's velocity vector. Participants confirm the correctness of the equations and suggest methods for integration, including standard substitutions for trigonometric functions. There is also clarification regarding potential transcription errors in the equations, emphasizing the importance of accurately setting up the problem. Overall, the thread provides insights into solving the differential equations related to the scenario.
GregoryGr
A boy is on a boat, at a distance H from the shore, when he sees a girl (at the point on the shore where the distance is measured) running with a constant velocity u parallel to the shore. At that time, he moves towards her, with a speed v, in such a way, that the point of the boat is always pointed at the girl (so his vector is always pointing her way). Find the time of their meeting.
$$ \vec{v}= \frac{dr}{dt}\hat{r}+r\frac{d\theta}{dt}\hat{\theta} $$
I changed the system of coordinates so the girl is stationary at O' , and using polar coordinates since the vector of the boat is always in the radial direction. The velocity for the boat in polar coordinates can be written:
$$ \vec{v}= -(v+ucos\theta)\hat{r}+vsin\theta\hat{\theta} $$
And since the 2 quantities in front of the singular vectors must be the same, I get 2 differential equations which give me this:
$$ \frac{dr}{r}= \frac{-(v-ucos\theta)d\theta}{usin\theta} $$
I am a noob at solving differentials, so firstly, are my equations right, and second, can somebody help me figure out how to do the math? :confused:
Yes, I agree with your first two equations, and I think the third is right. Once you have a solution you can check it satisfies the second one.
If you expand the numerator, the second term is easy to integrate. The first becomes the integral of a cosecant, which is standard enough that you can look it up. If you're interested in doing it from first principles, multiply top and bottom by sine and convert the sin2 in the denominator to 1-cos2. You can then factorise that and expand it using partial fractions. Each fraction is readily integrated.
I think there should be "u" instead of v in front of sinθ. Check.
ehild
Likes 1 person
ehild
Yes, I saw that, but it must be a transcription error since it is correct in the later equation.
A figure would be necessary. I assume that the girl runs to the left so the boy has a horizontal velocity component u to the right. See figure. That component and the boy's radial velocity component v add up and determine the boy's next position.
You see that the horizontal component u makes r increase, but θ decrease.
In case the girl run to the right, the boy would move in the second quadrant, the angle θ would increase as the boy approaches the girl.
What is your set-up? Check the signs.
ehild
There is a standard substitution when you have to integrate a rational function of sines and cosines. All trigonometric functions can be written in terms of tan(x/2), and then the substitution z=tan(x/2), dx = 2/(1+z2) dz can be used.
\sin(x)= \frac {2\tan(x/2)}{1+\tan^2(x/2)}
\cos(x)= \frac {1-\tan^2(x/2)}{1+\tan^2(x/2)}
\int {\frac{1}{\sin(x)}= \frac {1+\tan^2(x/2)}{2\tan(x/2)}dx}= \int {\frac {1+z^2}{2z}2 \frac{1}{1+z^2}dz}=\int {\frac {1}{z} dz}= \log|tan(x/2)|+Cehild
