Mph jet engine reaches 2 atmosphere 29.4 psi
The discussion focuses on the relationship between jet engine speed and ram air pressure, specifically how fast a jet must travel to achieve 2, 3, and 4 atmospheres of pressure. It notes that Bernoulli's equation is not applicable in compressible flow situations, which are relevant at high speeds. The conversation highlights that achieving double atmospheric pressure requires speeds around Mach 1.04, while triple and quadruple pressures require Mach 1.37 and 1.56, respectively. The complexities of compressible flow and shockwave formation are emphasized, as well as the need for specific assumptions to accurately calculate these pressures. Overall, the topic underscores the challenges in determining the necessary speeds for significant pressure increases in jet engines.
gary350
As a jet engine travels through the sky and picks up speed ram air increases the air pressure at the air intalk of the engine. How many mph does the engine have to be going for ram air to 2 atmospheres = 29.4 psi?
At what speed in mph = 3 atmospheres?
4 atmospheres?
Is this a linear or nonlinear increase in air pressure vs mph?
Science news on Phys.org
russ_watters said:
Read the wiki link on Bernoulli's principle.
Bernoulli's equation would predict a velocity faster than the speed of sound, it's safe to assume any such situation is compressible and therefore not subject to Bernoulli's equation. The real issue here is that there isn't nearly enough information to answer such a question without making some major assumptions.
If the compression is isentropic, then the flow would have to be moving at something like Mach 1.04 to achieve double the atmospheric pressure, Mach 1.37 to triple the pressure, and 1.56 to quadruple it. That's just form isentropic stagnation, though, and discounts the formation of shocks, which are quite likely to occur here.
Bernoulli's equation can include a term for compressibility and that's discussed in the wiki.
But yes, the bigger problem is what the highest pressure you see is before reaching supersonic or choked flow.
Either way though, IMO one should start at zero and work their way up on this issue. That at least partially answers the last question.
The bigger problem is what the highest pressure you see is before reaching supersonic or choked flow.
Using the compressible version of the Bernoulli equation requires you to know how the density evolves, which requires all the same assumptions I mentioned before. Also, it seems pretty obvious that the OP doesn't know what he/she is doing here is would probably jump straight to the normal Bernoulli equation if all you do is tell him to read the wiki link on the Bernoulli equation, so I don't think that's the right approach. At any rate, assuming something like an isentropic compression or a normal shock let's you relate the Mach number directly to the pressure ratio, so that approach is going to be substantially easier anyway.
I edited my previous post to include the Mach numbers required to achieve those compressions assuming the flow is isentropic, and they are pretty clearly supersonic. The compression ratio to achieve sonic flow in air is ##p/p_0 \leq 0.528##, and the OP is asking about 0.5, 0.33, and 0.25.
A side issue here is the speed of the intake flow into the jet engine. Relative to the jet, the intake air isn't stopped, it's just slowed down, so the speed decrease from free stream to intake speed needs to match the numbers posted by boneh3ad. In the case of most supersonic (not hypersonic) jets, the flow is slowed to subsonic, sometimes via the use of shockwaves.
I need to calculate the amount of water condensed from a DX cooling coil per hour given the size of the expansion coil (the total condensing surface area), the incoming air temperature, the amount of air flow from the fan, the BTU capacity of the compressor and the incoming air humidity. There are lots of condenser calculators around but they all need the air flow and incoming and outgoing humidity and then give a total volume of condensed water but I need more than that. The size of the...
Thread 'Why work is PdV and not (P+dP)dV in an isothermal process?'
Let's say we have a cylinder of volume V1 with a frictionless movable piston and some gas trapped inside with pressure P1 and temperature T1. On top of the piston lay some small pebbles that add weight and essentially create the pressure P1. Also the system is inside a reservoir of water that keeps its temperature constant at T1. The system is in equilibrium at V1, P1, T1. Now let's say i put another very small pebble on top of the piston (0,00001kg) and after some seconds the system...
I was watching a Khan Academy video on entropy called: Reconciling thermodynamic and state definitions of entropy. So in the video it says: Let's say I have a container. And in that container, I have gas particles and they're bouncing around like gas particles tend to do, creating some pressure on the container of a certain volume. And let's say I have n particles. Now, each of these particles could be in x different states. Now, if each of them can be in x different states, how many total...
18K
