Multivariate Calculus Chain Rule.
jaguar7
Apply the two cases of th change rule. For example: The voltage V in an electrical circuit is slowly decreasing as a battery wears out and the resistance R is slowly increasing as the resistor heats up Use Ohm's law V=IR to find how the current is changing (with respect to time) at the instant that R = 400 ohms, I = 0.08A, dV/dt = -0.01V/s, and dR/dt = .03 ohms/s. (Answ: -3.1 * 10^(-5)A/s)
I guess we have three variables, V, I, and R. Do we use the multiplication rule and get (dV/dt = R dI/dt + I dR/dt) ?
Sure. Solve this equation for dI/dt, and evaluate it for the given values of I, R, dV/dt, and dR/dt.
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
