My old laptop fails to connect to the wifi
  • Thread starter Thread starter yungman
    Laptop Wifi
An old laptop is failing to connect to Wi-Fi, displaying the message "Windows can't communicate with the device or resource." The issue is not with the wireless modem, as other devices connect without problems. Potential causes include outdated security protocols or compatibility issues with the Wi-Fi router. Troubleshooting steps suggested include restarting the laptop and router, checking the status of the DHCP and DNS Client services, and flushing the DNS cache. If these do not resolve the issue, resetting the TCP/IP stack may be necessary. Additionally, verifying whether the laptop previously connected to the same Wi-Fi network and ensuring it uses compatible security protocols are recommended. Concerns about the laptop being infected may also need clarification, as a simple browser popup does not necessarily indicate infection.
yungman
Hi
While I am working with Norton to fix my other computer, I have to pull out my old laptop to use at the mean time. It fails to connect to my wifi. It was working before two years ago, now it's not working. I open the troubleshoot and it detected that "Windows can't communicate with the device or resource".
The signal is good, I type in the Network security key and it's not communicating.
My infected laptop communicates just fine and so is my wife's laptop. So it's definitely not the wireless modem. It's the old laptop. Can anyone help?
Thanks
Computer science news on Phys.org
Could it be the security protocol that you are using? In troubleshooting, you could try to eliminate some factors. Perhaps take the laptop to a friend's house or a coffee shop to see if you can connect, there.
I had a similar problem (a couple of years ago), at some point, with more than one device. I called my internet carrier and it turned out they had changed their frequencies or something. They made an adjustment from their controls for my account, to cover those specific devices, I think (perhaps in a virtual environment, some of them). Then they asked me to restart all affected devices as well as the wifi router, for the devices to get new IP #s ..., etc.
Could it be that?
Or, first of all, have tried just restarting everything a couple of times, until they connect?
[+If it fails:]
Then try connecting manually ...
Then troubleshooting etc.
Then call your carrier etc. ... (+above)
Does this message also include "primary DNS server"? In this case the security software you're using may be at issue.
Check if the DNS Client and the DHCP Client services are running. Depending on the Windows version you're using, find a search dialog box and type "services.msc" (without the quotes). Now, in the services panel look for the services "DHCP Client" and "DNS Client". You can right-click each service and by clicking "Properties" you can check if it is running. In the dependencies tab you can check if the dependent services are also running. If you can't resolve the issue this way then try to flush the DNS cache. Let me know if you want help on this. If you can't solve the problem even this way you may need to reset the TCP/IP stack.
Likes Stavros Kiri
Thanks Q
Thanks for the reply, I'll check tomorrow when I have the laptop out and look at the message. Have to clean everything up for guess to come tonight.
Thanks
Just checking, did it work with the same wifi box you have now, or did you replace it?
I'm asking because there are different types of wifi. See e.g. https://support.metageek.com/hc/en-us/articles/202162320-WiFi-Phy-Types for a list including their backward compatibilities.
In other words, there could be a compatibility issue.
Alternatively, you may want to check the security protocols.
It's possible they have been upgraded to newer versions.
To check, see which protocols you're using on the working laptop, and see if you have the same on the older laptop.
Btw, I noticed you mentioning 'your infected laptop'.
Are you sure it is infected? If there was just a popup in a web browser that looked alarming, but went away before you could take proper note of it, then I don't think it is infected. If that's the case you only need a better web blocker.
I came across a video regarding the use of AI/ML to work through complex datasets to determine complicated protein structures. It is a promising and beneficial use of AI/ML. AlphaFold - The Most Useful Thing AI Has Ever Done https://www.ebi.ac.uk/training/online/courses/alphafold/an-introductory-guide-to-its-strengths-and-limitations/what-is-alphafold/ https://en.wikipedia.org/wiki/AlphaFold https://deepmind.google/about/ Edit/update: The AlphaFold article in Nature John Jumper...
Thread 'Urgent: Physically repair - or bypass - power button on Asus laptop'
Asus Vivobook S14 flip. The power button is wrecked. Unable to turn it on AT ALL. We can get into how and why it got wrecked later, but suffice to say a kitchen knife was involved: These buttons do want to NOT come off, not like other lappies, where they can snap in and out. And they sure don't go back on. So, in the absence of a longer-term solution that might involve a replacement, is there any way I can activate the power button, like with a paperclip or wire or something? It looks...
