Mysterious Window: Force It to Move or Find the Process Name?
  • Thread starter grady
  • Tags
    Window
In summary, the top of this window is appearing at the bottom of the screen. It is possible that someone is hacking the PC. To get the window to move, the user closes all applications and switches to the task manager. The window's name is recorded and then it is closed with task manager.
grady
70
Why is the top of this window appearing at the bottom of the screen? Am I being HACKED! OMG I can't move the window and there isn't anything but the normal spyware that the cable company installs in the task manager. Does anyone know how to force a window to move or how I might link this window to a process name?
http://members.cox.net/gradyfield/hacked.jpg
Computer science news on Phys.org
First thing I'd do is close all applications.
Press ALT and TAB to switch to that bring the mystery window to the top of the task manager list.
Then, hit CTRL-ALT-DEL to bring up the task manager.
Record the name of the open window, which hopefully will be at the top of the list in Task Manager. Then, using task manager, close the window.
Look in your startup folder under program files and see if anything matching that window name is in there.
I take it you are not able to move the window into view. I've seen things like this, seems a lot of times it is just an auto advertisment loader that sites launch on your pc as a popup window so that they can bombard you with advertisment popups.
Tell me this, do you get a lot of adverts?
Thanks for the tip on the task manager. I didn't know the current window was put at the top. The window isn't movable, and if I right click it, Move and Restore (faded out ) are on the menu. If i click move, the 4 directional arrow comes up for a second or two and the window disappears.
I have a firewall installed, so even if it were a program to beckon popup adds to the desktop, either it or they would be stopped I think. The next time the window comes up i'll tell you what the process name is, it comes up at least once a day.
If what annoys you is seeing the window, and not is precense, you can :
1-Check that the taskbar's always on top is enabled.
2-Use a program to catch the window's ClassName, then make a program to hide that window on start up (programatically). This can be done in VB (if it really annoys you, i can do this for you).
Originally posted by grady
Thanks for the tip on the task manager...
How did task manager identify the window?
PROGRAMMING TO GET RID OF SPAM Talk about swatting a fly with a tank! Just control,alt,del and get the file name. Do a search both through start>find> files or folders, and also do a search of the registry. You can do this by going to start> run and typing in regedit. Then hit F3, which brings up the search menu, and do a search for the file in there. It's either in the windows startup folder, in the HKLM>SOFTWARE>MICROSOFT>WINDOWS>CURRENT VERSION<RUN directory in the registry, or both.
Edit: not to scare you, but you want to get it off there. Although it's unlikely, it's always possible someone's attempting to hack your PC, though it's unlikely given that you have a firewall.
Related to Mysterious Window: Force It to Move or Find the Process Name?
1. What is the Mysterious Window?
The Mysterious Window is a pop-up window that appears on your computer screen without any clear indication of what program or process it belongs to.
2. How can I force the Mysterious Window to move?
You can force the Mysterious Window to move by using the task manager or process explorer to end the process associated with the window. This will close the window and allow you to continue using your computer.
3. Why does the Mysterious Window appear?
The Mysterious Window can appear for various reasons such as a malfunctioning program, a virus or malware, or a system error. It could also be caused by a background process that is not visible to the user.
4. Can I find the process name associated with the Mysterious Window?
Yes, you can find the process name associated with the Mysterious Window by using the task manager or process explorer and looking for the process that is using the most CPU or memory. This will typically be the process causing the window to appear.
5. How can I prevent the Mysterious Window from appearing?
To prevent the Mysterious Window from appearing, you can regularly scan your computer for viruses and malware, keep your operating system and programs up to date, and be cautious when downloading or opening files from unknown sources. You can also use a reliable antivirus software to help detect and prevent any potential threats.
  • Computing and Technology
15K
  • Classical Physics
13K
  • Other Physics Topics
  • Quantum Interpretations and Foundations
