Diagonalizing Linear Operators: Understanding the Differences
db1uover
Let V be a n-dimensional real vector space and L: V --> V be a linear operator. Then,
A.) L can always be diagonalized
B.) L can be diagonalized only if L has n distinct eigenvalues
C.) L can be diagonalized if all the n eigenvalues of L are real
D.) Knowing the eigenvalues is always enough to decide if L can be diagonalized or not
E.) L can be diagonalized if all its n eigenvalues are distinct
I have the answer, but I don't understand the slight differences between 'only if L has n distinct eigenv' and 'if all its n eigenv are distinct'. Can someone explain how the statements have different meanings?
Starting with the assumption that the statements are different, I understood it as Ans B means must have only n eigenv while Ans E is slightly more flexible in its requirements. Is this correct? Is there more to the story?
B means L can be diagonalized only if all of its eigenvalues are distinct; if any are repeated, you can't diagonalize L.
E means if the eigenvalues are distinct, then you can diagonalize L. It doesn't say anything about the case of repeated eigenvalues.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
