Natural units and electron mass
In summary, the conversation discusses the conversion of physical constants into natural units of ##c=1## and ##\hbar=1##, specifically focusing on the electron mass expressed in MeV and the conversion factor to cm^-1. It also mentions the use of Plank units to deal with mass-energy and the normalization of the gravitational constant. The correct conversion factor for the electron mass is ##\frac{0.511 \text{MeV}}{\hbar c} = 2.58 \times 10^{12} \text{cm}^{-1}##.
spaghetti3451
1,344
33
I am trying to express some physical constants in natural units of ##c=1## and ##\hbar=1##.
Let's start with the electron mass. In SI units, the electron mass is ##0.511 \text{MeV}/c^{2}##. I understand that in natural units, the electron mass is simply ##0.511\ \text{MeV}##. Now, is the electron mass given by ##\frac{\hbar c}{0.511 \text{MeV}} = 1.01 \times 10^{-21}\ \text{cm}##?
Notice that expressing mass in MeV alreafy has c=1 factored in - so why would the conversion factor have an explicit c in it?
How often do you normally convert units by dividing by the quantity you are converting?
When you convert quantity x from unit a into unit b, wouldn't you just multiply it by a conversion factor?
Observations:
To convert MeV into natural units of length, you need to know how many natural length units there are in 1MeV.
In general - setting ##\hbar = c = 1## still leaves some arbitrary units.
A "centimeter" is not usually a natural unit.
See, for example, plank units.
https://en.wikipedia.org/wiki/Natural_units#Planck_units
It looks like the calculation you did just normalizes the electron rest mass and tells you how big the unit of length is, in terms of other systems of units, for the particular set of natural units chosen.
The mass expressed in ##\text{MeV}## needs to be converted to ##\text{cm}^{-1}##. Now, ##\frac{\text{MeV}}{\hbar c}## has dimensions of length. Therefore, ##\frac{1 \text{MeV}}{\hbar c}## gives the conversion factor from ##\text{MeV}## to ##\text{cm}^{-1}## in SI units.
There is a typo in my calculation. It is actually ##\frac{0.511 \text{MeV}}{\hbar c} = 2.58 \times 10^{12} \text{cm}^{-1}##.
It does, but this system of units is heavily used in particle physics and cosmology.
What do you think?
You seem to be thinking of plank units ... to deal with mass-energy you usually need to also normalize the gravitational constant.
Other schemes normalize the mass of the electron or some other particle commonly dealt with... which amounts to picking a different value for G.
If m is the electron mass, then ##(mc^2)/\hbar c## gives dimensions of [E]/[E.L] = L^-1 ... so that comes out right for you... just makes sure you express ##\hbar c## in units of MeV.cm
Related to Natural units and electron mass
What are natural units?
Natural units are a system of measurement where fundamental physical constants, such as the speed of light and the gravitational constant, are set to a value of 1. This eliminates the need for conversion factors and simplifies equations in theoretical physics.
How is the electron mass measured in natural units?
In natural units, the electron mass is defined as 1. This means that it is the fundamental unit of mass in this system, and all other masses are expressed as a multiple of the electron mass.
Why is the electron mass significant in natural units?
In addition to being a fundamental unit of mass, the electron mass is also used as a reference point for other particles. For example, the proton mass is approximately 1836 times the electron mass in natural units.
Do all physical quantities have natural units?
No, not all physical quantities have natural units. Only fundamental quantities, such as mass, length, and time, can be expressed in natural units. Other quantities, such as temperature and electric charge, cannot be measured in natural units.
How are natural units used in theoretical physics?
Natural units are commonly used in theoretical physics, particularly in quantum field theory and particle physics. They simplify equations and allow for a more elegant and intuitive understanding of fundamental physical concepts.
  • Other Physics Topics
  • Electromagnetism
