I Nearly Lorentz Coordinate Systems: Is h a Tensor?
Silviu
Hello! I am reading Schutz A first course in GR and he introduces the Nearly Lorentz coordinate systems as ones having a metric such that ##g_{\alpha\beta} = \eta_{\alpha\beta} + h_{\alpha\beta}##, with h a small deviation from the normal Minkowski metric. Then he introduces the Background Lorentz transformations (this is section 8.3 in the second edition) in which all the points are transformed as ##x^{\bar\alpha}=\Lambda_\beta^{\bar\alpha}x^\beta##. Applying this transformation to g he gets in the end that h transforms as ##h_{\bar\alpha\bar\beta}=\Lambda_\mu^{\bar\alpha}\Lambda_\nu^{\bar\beta} h_{\mu\nu}## and from here he says that we can treat h as if it was a tensor in SR and this simplify the calculations a lot. Can someone explain to me why ones need all these calculations for this? I am sure I am missing something but h is the difference between g and ##\eta## so isn't it a tensor, just because it is the difference between 2 tensors? Why do you need a proof for it? Moreover Schutz says that h "it is, of course, not a tensor, but just a piece of ##g_{\alpha\beta}##". So can someone explain to me why isn't h a tensor and why my logic is flawed? Thank you!
Why is ##\eta_{\alpha\beta}## a tensor?
Well a tensor (in this case a ##(0,2)## tensor) is a function that turns 2 vectors into a real number. ##\eta## is a 4x4 matrix so it behaves like a ##(0,2)## tensor, when applied to a 4D vector (which is our case).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
