Need Check on Collision Question
  • Thread starter Thread starter tachu101
    Collision
The discussion revolves around a collision problem involving two masses where mass 1 is moving and mass 2 is at rest. The user calculated the final velocities of both masses after the collision, arriving at 0.0838 m/s for mass 1 and 2.08 m/s for mass 2. They confirmed using both momentum and energy conservation principles in their calculations. Other participants validated the approach, emphasizing the importance of using both methods for accurate results. The conversation highlights the integration of momentum and energy in solving collision problems.
tachu101
A mass 1 is moving at a constant velocity and collides with a ball of mass 2 that is at rest. What are the final velocities of the masses and the direction of the velocity?
Mass 1 = 4.35kg
Initial Velocity of mass 1= 2m/s
Mass 2 = 4.00
Initial Velocity of mass 2 = 0 m/s
I calculated .0838 m/s for the mass 1 and 2.08 m/s for mass 2. I used momentum to calculate the answers. Can anyone check this?
That's right. But you didn't just use momentum, did you? You used energy as well.
yes I used both together. Thanks
