Get Expert Tips for Proving the Product Rule Using Gradient Method
  • Thread starter Thread starter Fjolvar
    Class
Fjolvar
I've been up for hours trying to figure out the proper notation to prove problem #4 (1.6.5) on the attached files. I'm not sure how to set this up. It is basically proving the product rule using the gradient of two functions. The rest of the problem is on the backside file, but help getting started on the first part would be enough. Any help would be greatly appreciated. Thanks!
Any ideas?
It looks to me like a pretty standard "just plug it in and calculate"!
You are asked to show that \nabla(uv)= \nabla(u)v+ u\nabla(v) where u and v are scalar valued functions of variables x and y. This is, basically, just the "product rule" for gradients.
Okay,
\nabla(uv)= \frac{\partial uv}{\partial x}\vec{i}+ \frac{\partial uv}{\partial y}\vec{j}
Apply the product rule to both partial derivatives:
\nabla(uv)= \left(u\frac{\partial v}{\partial x}+ \frac{\partial u}{\partial x}v\right)\vec{i}+ \left(u\frac{\partial v}{\partial y}+ \frac{\partial u}{\partial y}v\right)\vec{j}
and regroup.
For part (a), if f(u, v)= 0 (where f is differentiable- that is NOT stated in the text but is necessary), then
\frac{\partial f}{\partial x}= \frac{\partial f}{\partial u}\frac{\partial u}{\partial x}+ \frac{\partial f}{\partial v}\frac{\partial v}{\partial x}= 0
and
\frac{\partial f}{\partial y}= \frac{\partial f}{\partial u}\frac{\partial u}{\partial y}+ \frac{\partial f}{\partial v}\frac{\partial v}{\partial y}= 0
Think of those as two equations to solve for the "unknowns" \partial f/\partial u and \partial f/\partial v. What condition on the "coefficients", \partial u/\partial x, \partial u/\partial y, \partial v/\partial x, and \partial v/\partial y is necessary in order that that have a solution (think about the determinant of the matrix of coefficients- that's the point of (b)).
Thank you very much, I think I've got it from here.
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
