Need help calculating maximum height
To calculate the time for the liquid to return to the syringe level, the equation y=(vi)(t)-0.5(g)(t^2) is applied, resulting in a time of approximately 0.27 seconds. For determining the maximum height, the time to reach the peak is calculated using the formula v = a*t, leading to a time of 0.13 seconds. The total time for the liquid's journey is double this value, approximately 0.27 seconds. The maximum height can then be found using the formula y = 0.5*g*t^2, where g is the acceleration due to gravity. This approach effectively solves both parts of the problem.
farhan769
A doctor, preparing to give a patient an injection, squirts a small amount of liquid straight upward from a syringe.
a) If the liquid emerges with a speed of 1.3 , how long does it take for it to return to the level of the syringe?
b) What is the maximum height of the liquid above the syringe?
y=(vi)(t)-.5(g)(t^2)
d=vt
i'm really not sure what equation to use
for part a i use y=(vi)(t)-.5(g)(t^2)
0=1.3t-.5(-9.8)(t^2)
t=.27s
I'm really not sure about part b, could someone help me with it
thanks
OK. We'll go with 1.3 m/s (you must include units ... it matters).
The easy way is to observe that
v = a*t
so the time to max height will be given by
1.3 = 9.8*t or t = 1.3/9.8.
Since total time is time up + time down ... double that giving 1.3*2/9.8
Since y = 1/2*g*t2 then just use the time found to max height from before of 1.3/9.8
