Need help for ultrasonitc atomizer (transducer)
  • Context: Undergrad
  • Thread starter Thread starter MRoydev
    Transducer Ultrasonic
This discussion focuses on the challenges of prototyping an ultrasonic transducer operating at a frequency of 50 kHz. Key issues include calculating the dimensions of the horn and back mass, with specific emphasis on the importance of the back mass length in millimeters for proper phase delay. The user is experimenting with materials such as AL2017 and SS417/420, and has noted significant temperature increases beyond 50°C after 30 seconds of operation. The design considerations include using half wavelength for the horn, which measures 25.48 mm, while the back mass is significantly shorter at 10 mm.
  • Understanding of ultrasonic transducer design principles
  • Knowledge of wave propagation and phase delay calculations
  • Familiarity with materials like AL2017 and SS417/420
  • Experience with temperature management in electronic devices
  • Research the calculation methods for back mass dimensions in ultrasonic transducers
  • Learn about the effects of temperature on ultrasonic transducer performance
  • Explore design variations of ultrasonic horns, including exponential taper designs
  • Investigate the properties of materials suitable for ultrasonic applications, focusing on sound speed
Engineers, researchers, and hobbyists involved in the design and prototyping of ultrasonic transducers, particularly those working with frequency-specific applications and material selection.
MRoydev
I am trying to prototype ultrasonic transducer, but it is little difficult. I did't found a lot of articles about it, the hard work is how to calc the the dimensions of the horn and the back mass, we are working at 50 kHz frequency. I have generator with regulator for the frequency we havo some prototypes which have worked from AL2017 now I am trying to make it from SS417/420. I have another problem with the temperture after 30 sec of work it is more then 50 C deg. It is working at half sound lenght, from what I saw there are different design, half sound lenght , one and two. If some need more information i will share and for is little difficult to understand the physics behind it.
Thanks for the heml
Welcome to PF.
MRoydev said:
... the hard work is how to calc the the dimensions of ... the back mass, we are working at 50 kHz frequency.
It is not the back-mass in kg that is important, it is the length in millimetres of the back-mass that must be dimensioned, to reflect the wave with the correct phase delay. That requires knowing the speed of sound in the back-mass material.
How do you arrange a horn to atomise, a liquid?
I would expect an exponential taper to a smaller section.
Hi Baluncore,
Thank you for the great welcome. I am currently trying with this scheme, from my calculation the lenght of the wave is 101.92 mm long and we are currently using half wave lenght and the horn is 25.48 mm, but the back is shorter. We have one chines trasducer like this one on the picture which have back mass with lenght only 10 mm.
  • · Replies 18 ·
