Is angular momentum of the planet conserved?
In summary, "mrv" represents the angular momentum of a planet and "conserved" means that it does not change with time. The force of gravity from the sun is an external force, so the ordinary momentum is not conserved for planets. However, angular momentum is conserved as long as the force is perpendicular to the line of motion, which is close enough to being true for planets moving in elliptical orbits.
Astronomer107
31
What is it meant by:
mr(1)V(1)= mr(2)v(2)
The quantity mrv is called the angular momentum of the planet. Is angular momentum of the planet conserved?
What do they mean conserved?? Thanks and sorry such short notice... my physics teacher soooo nicely gave us 2 days notice to finish all the labs for the 2nd marking period by tomorrow, which is in a half hour and I need some sleep, thanks.
"Conserved" means "doesn't change with time".
"mrv" is mass (m) times distance from the sun (r) times velocity (v).
Ordinary momentum itself is conserved (doesn't change as ambitwistor said) as long as there is no external force on the object.
That's not true for planets- the force of gravity from the sun is an external force.
Angular momentum is conserved if the force is perpendicular to the line of motion. Since planets move in ellipses rather than circles, that is not exactly true but the ellipses are so close to being circles that for most planets the difference is not very large.
Related to Is angular momentum of the planet conserved?
1. What is angular momentum?
Angular momentum is a measure of the rotational motion of an object or system. It is defined as the product of its moment of inertia and its angular velocity.
2. How is angular momentum conserved?
Angular momentum is conserved in a closed system, meaning there are no external forces acting on the system. This means that the total angular momentum of the system remains constant over time.
3. How does this apply to the planet?
The planet is a closed system, meaning there are no external forces acting on it (neglecting gravitational pull from other celestial bodies). Therefore, the angular momentum of the planet is conserved.
4. What factors affect the angular momentum of the planet?
The angular momentum of the planet is affected by its mass, moment of inertia, and its rotational speed. Changes in any of these factors can result in a change in the planet's angular momentum.
5. Why is it important to study the conservation of angular momentum in planets?
Understanding the conservation of angular momentum in planets helps us better understand their rotational motion and the factors that influence it. It also allows us to make predictions about the future behavior of planets and other celestial bodies.
10K
