Need help in comsol multiphysics
The discussion revolves around seeking assistance with COMSOL Multiphysics, specifically regarding how to initiate a project. The user expresses uncertainty about starting and requests help from the community. Suggestions include beginning with geometric modeling, followed by defining boundary and initial conditions. There is a consensus that this approach is a logical starting point for using the software effectively. The conversation emphasizes the importance of understanding the problem before proceeding with modeling.
stephenzztant
Hi guys,
i simply don't know how to start tis thing with...
please help...
P/S : pls find the attached.
Do you understand the problem? I would start with geometric modelling. Boundary conditions and intial conditions would follow. I have not used comsol, but I think that is the way to go.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
