Need help on figuring out weight distribution when adding a third axle
The discussion focuses on calculating weight distribution when adding a third axle to a truck weighing 20,000 lbs, with specific weights on the front and rear axles. The center of gravity is determined to be 161.84 inches, and the average wheelbase is calculated at 246 inches when a 26,000 lb payload is added. The rear load is estimated at 13,158 lbs, leading to 6,579 lbs on each rear axle and 6,842 lbs on the front axle. The distribution can be influenced by the stiffness and preload of the rear axle suspensions, affecting how the load is shared. Accurate calculations require considering these factors to determine the load on each axle effectively.
rlpjr
We have a truck that weighs 20,000 lbs, 8,100 on the front and 11,900 on the rear. The wheel base from the front axle to the rear axle is 272". The center of gravity is 161.84" which we found by taking 272" * 11,900 / 20,000 = 161.84".
What would the load be on each axle if we add a third axle that weighs nothing (for the sake of keeping it simple) at 220" that is an 'independent non-load sharing axle'? Meaning its just like the original rear axle and not like a normal tandem setup that shares (splits) a load evenly between the two.
Any insight into this is much appreciated,
Thanks.
p.s.
To get more into it what would the loads be on each axle when we add a payload of 26,000 lbs at 200"?
Even if it is an independent axle, you still need to find an «average» wheelbase between the front and the rear axles and split the rear load evenly between the two rear axles.
So the «average» wheelbase would be 246", the rear load would 13 158 lb (so 6579 lb on each rear axle) and 6842 lb on the front axle.
Although, the split between the two rear axles will be affected if one of the rear axle has a much stiffer suspension than the other, or if the springs of one rear axle are more preloaded than the ones from the other rear axle. The stiffer or more preloaded axle will support more weight.
So the rear load (Fr) is related to the initial preload of the springs (Fpl), the stiffness of the springs (K) and the displacement of the springs (x) on the two rear axles (1 & 2):
Fr = (Fpl 1 + K1x) + (Fpl 2 + K2x)
or:
x = [Fr - (Fpl 1 + Fpl 2)] / (K1 + K2)
The displacement x is the same for both axles. You can then find the load on each axle by adding its preload and the force created by the displacement.
Posted June 2024 - 15 years after starting this class. I have learned a whole lot. To get to the short course on making your stock car, late model, hobby stock E-mod handle, look at the index below. Read all posts on Roll Center, Jacking effect and Why does car drive straight to the wall when I gas it? Also read You really have two race cars. This will cover 90% of problems you have. Simply put, the car pushes going in and is loose coming out. You do not have enuff downforce on the right...
I'm trying to decide what size and type of galvanized steel I need for 2 cantilever extensions. The cantilever is 5 ft. The space between the two cantilever arms is a 17 ft Gap the center 7 ft of the 17 ft Gap we'll need to Bear approximately 17,000 lb spread evenly from the front of the cantilever to the back of the cantilever over 5 ft. I will put support beams across these cantilever arms to support the load evenly
Thread 'What's the most likely cause for this carbon seal crack?'
We have a molded carbon graphite seal that is used in an inline axial piston, variable displacement hydraulic pump. One of our customers reported that, when using the “A” parts in the past, they only needed to replace them due to normal wear. However, after switching to our parts, the replacement cycle seems to be much shorter due to “broken” or “cracked” failures. This issue was identified after hydraulic fluid leakage was observed. According to their records, the same problem has occurred...
