How Do You Apply Calculus to Determine Force in Physics?
  • Thread starter Thread starter glennpagano44
    Apply Calculus
In physics, to determine force from potential energy, you take the derivative of the potential energy function. This is because force is defined as the negative gradient of potential energy, expressed mathematically as F = -dPE/dx. The relationship between energy and force is established through the units, where energy in Joules relates to force in Newtons over distance. When given a potential energy function, differentiating it with respect to position will yield the force as a function of position. Understanding these principles allows for effective application of calculus in physics problems involving force and energy.
glennpagano44
Right now I am in AP physics in High School, while also taking calculus and I need some assitance on when and how to apply the calculus (once I know to do calculus I can go from there)
Example
If Potential Energy is 5x^2+3x+7 what function is the force.
- I know you have to take derivative of the PE equation because my teacher told me.
Also because -PE=Fdcos the you get -PE/d=F. From there how do you know to put dPE/dd =F. Also how do you know not to integrate.
Thanks Alot
You can look at the units if nothing else.
Forces are in Newtons N and energy is in Joules which are N-m
If you have Joules then the rate of changes in Joules by x should yield Newtons.
If you have Newtons exerted over a distance x, the integral of F⋅X (F as a function of x) yields you Joules - energy.
In your problem you're wanting to know the F as a function of x and you are given the energy potentials PE as a function of x. Hence dPE/dx should yield you your Force as a function of x.
Thanks a lot LowlyPion that helped out. Anyone else have any input?
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
