Need help plotting a 4th order polynomial
A user is seeking assistance with plotting a fourth-order polynomial due to a lost graphing calculator and difficulties with synthetic division. The polynomial equation provided is complex, and the user emphasizes the need for precise x values for an engineering problem. Suggestions include using Wolfram Alpha and Excel for calculations, with one participant noting that there is no real solution to the equation. The user expresses frustration over previous calculations and appreciates the help received, particularly in learning to use Excel for polynomial problems. The discussion highlights the challenges of working with intricate polynomial equations and the utility of alternative tools for solving them.
david martin
I need help from someone with a graphing calculator. My little brother lost my graphing calculator and synthetic division I can't make work becasue the terms aren't exactly friendly. The equation is,
24.059025x^4 + 94.98287069x^3 + 44.56696001x^2 - 827.1103204x = -1067.832496
The more precise the x value the better, since it is a engineering type problem.
Thanks,
Thanks,
If you have access to a spreadsheet you can use that.
RGV
Good news. There's no real solution.
Thats bad news. I worked through two full pages of nasty algebra to get it to a simplified polynomial state, not to mention the four previous pages of prior calculations. Maybe I made a simple algebra mistake. I'm dreading having to go back and waste more time on this problem.
Thanks Ray for the spread sheet suggestion. I always knew excel could work with polynomials but never used it. This problem forced me to learn how to use it, very powerful tool. Excel gave me a value but not anything close to what I had expected.
Thanks again for eveyones help
