Need help regarding finding out the max pressure in a isothermal cycle.
To determine the maximum pressure in the isothermal cycle, understanding the processes is crucial. During isothermal compression, the gas's pressure increases while maintaining a constant temperature. In the isobaric heating phase, the pressure remains unchanged as the gas returns to its original volume. Finally, during isochoric cooling, the volume is constant, leading to a decrease in pressure. The maximum pressure occurs at the end of the isothermal compression phase before the isobaric heating begins.
cochrad
A volume of 1.5 m3 of air initially at 1.31 bar and 293k undergoes three processes in order to complete a cycle:
Process
1 to 2 Isothermal compression from state 1 through a volumetric compression ratio of Rv to state 2
2 to 3 Isobaric heating back to the original volume.
3 to 1 Isochoric cooling back to state1.
How do i find the max pressure in the cycle?
Thanks
By knowing what the three iso... words mean.
You don't need any of the numbers or any equations - you just have to understand what the gas is doing.
i know what the three iso's mean. could you supply a little more help please
You need to know that PV/T = constant
The gas is compressed but at the same temperature so pressure does up.
Isobaric means no change in pressure.
Volume is constant but cooled so pressure goes down.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
