Discover the Steps to Solve for X in a Chemistry pH Equation
  • Thread starter Thread starter stressedout
To solve for x in the pH equation (x + 1*10^-8)(x) = 1.0*10^-14, first expand the equation to x^2 + 1*10^-8x - 1*10^-14 = 0. The quadratic formula, x = [-b ± sqrt(b^2 - 4ac)] / 2a, can then be applied, where a = 1, b = 1*10^-8, and c = -1*10^-14. After substituting these values, the correct solution for x is approximately 9.5 x 10^-8. The discussion emphasizes the importance of correctly applying the quadratic formula to resolve the confusion with the two x terms.
stressedout
Hi,
I have a mathematical problem coming from chemistry (dealing with pH). I've set everything up but can't do the math, I need the math steps to be shown to me.
How do you solve for x in this equation?
(x + 1*10^-8) (x) = 1.0*10^-14
x should be equal to 9.5 x 10^-8, but what steps do you take to get this value? I have tried this problem for a while and keep getting stuck because there are 2 x's on the left side of the equation. I don't know where to begin anymore or what to do. Any help would be appreciated. Thanks in advance.
please do not double post.
see this thread.
x^2 + 1*10^-8x=1*10^-14
x^2 + 1*10^-8x - 1*10^-14 =0
do you know quatratic formulas?
Sorry Integral, I posted and about 10 minutes later I thought I posted in the wrong section so I edited my post and decided maybe I should be posting my question here instead. Thank you for pointing me in the right direction for the solution (I looked at the other thread).
Thanks vincentchan, yes, I know the quadratic formula.
- b +/- sqrt b^2 - 4(a)(c) over 2a
I tried this at one point, but got confused and thought it was wrong. I'll try it again.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
