Need help with Electric Potential problem.
The discussion focuses on solving an electric potential problem from MIT's OpenCourseWare. The user is struggling with an equation related to the kinetic energy of a proton influenced by two charges. They mention the formula for electric potential energy, -k(Q1)(Q2)/r, and suggest evaluating the potential between the proton and one charge, then doubling it due to symmetry. The user is seeking assistance to correct their calculations, as their results yield an excessively large value. Clarification on the approach to calculating potential energy and kinetic energy is requested.
PhysicsGnome
I was going over that mit open courseware stuff and I ran into a problem I'm having trouble with...
http://www.phy.mtu.edu/~gagin/2200/textfiles/ph2200-ex2-f05.pdf
#23
The equation I have for it is:
vi = sqrt(2/m * ((K*1.5nC*e/.005m) + (K*1.5nC*e/.005m)))
But I'm getting to large a value... I've been playing around with it but can't seem to get it.
Thanks for any help.
First consider the proton between the charge and its total energy (it will be all potential). Then consider the particle very far away, such that it has zero potential energy, and all kinetic energy.
The formula for electrical potential energy is
-k(Q1)(Q2)/r
between any two point charges of charge Q1 and Q2, r the distance between them. We can evaluate the potential between the proton and one charge and multiply by two because the situation is symmetrical.
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
