Need Help With Geometry Problem (Circles)
  • Thread starter Thread starter Izzhov
    Circles Geometry
The geometry problem involves finding the radius of circle Q, which is tangent to circle P and a semicircle with diameter AB and center O, where OB is 4. The discussion highlights the need for three equations to define the position and radius of circle Q, considering its tangency to both circle P and the semicircle. Initially, the user struggled with deriving the necessary equations, particularly for the tangency condition with the semicircle. However, the user later resolved the issue independently. The problem emphasizes the relationship between the circles and the geometric constraints involved.
Izzhov
In the diagram below:
AB is the diameter of the semicircle with center O. Circles P and Q are tangent to each other and to the semicircle. If OB=4, find the radius of circle Q.
I haven't been able to make any headway at all with this problem. I tried to find a system of equations with the radius of circle Q equal to x and some other length equal to y, but all I found was that the length of the common external tangent of circles P and Q is 2 \sqrt{2x}, where x is the radius of circle Q, and I'm not sure how that's useful. Please help.
Let the origin be (0,0) in a cartesian coordinate system. The point P is then (0,2). Let the point Q be at position (x,y).
To define the position of a circle needs three equations. (There are 3 degrees of freedom, the position (x,y) of the center, and the radius.)
The radius of Q is y, this is one restriction.
The circle Q and P are tangent. This means that the distance from P to Q is equal to the sum of their radii.
The third restriction on the circle centered at Q is that it be tangent to the circle centered at O. This will be a quadratic equation in x and y.
I'd already figured out the first two restrictions, and I understood that the third restriction would have to do with circle Q being tangent to the semicircle, but I have no idea how to derive an equation from that.
EDIT: Never mind. I figured it out. Thank you.
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
