How Do Core Construction and Amp-Turns Affect Transformer Performance?
  • Thread starter Thread starter SMD1990
    Transformer
Core construction and amp-turns significantly influence transformer performance. Using toroidal cores and ensuring the core is laminated can enhance efficiency by preventing induced currents from circulating. A rule of thumb regarding amp-turns is essential, particularly in relation to the core's permeability. Interestingly, an early attempt with a straight rod yielded the best results, highlighting the importance of experimentation. Safety precautions are crucial when working with mains electricity.
SMD1990
Off and on, I have been messing with making a little transformer. My first attempt was last winter.
They never seem to really work very well.
Is there any sort of rule regarding the amp-turns needed around a core with a particular permeability?
My earliest attempts used a straight rod. More recently, I have been winding around toroidial cores. Typically, the greater of my windings has a hundred or more turns.
Strangely, one of my early "straight rod" attempts has actually provided to have best performance, thus far.
I would suggest you to break-apart a real transformer and work your way backward.
For Best performance, you need to use striped iron forming a closed loop.
But always be careful when playing with the mains.
The construction of the core is critical. For decent performance it has to be laminated such that no induced current is able to circulate in the plane perpendicular to the direction of the magnetic flux.
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
