Calculating Distance Traveled on an Inclined Plane: Mechanics Help Needed!"
  • Thread starter Thread starter wuffle
    Mechanics
The discussion centers on calculating the distance a block travels on an inclined plane before coming to rest after being projected upward. One participant calculates the acceleration as a(x) = 2gSin(alpha) and uses a distance formula S = -V^2/(4gsin(alpha)). Another participant argues that static friction is greater than kinetic friction and provides a different approach involving F(fric) and a = μ * mg * sin(α). There is confusion regarding the contributions of weight components to the block's motion and whether it will slide back down after stopping. Clarification on the forces acting on the block and the correct application of friction is needed to resolve the differing calculations.
wuffle
Once again, need help with mechanics, this one I think I did right, but my friend did it somehow different, and I was wondering who of us 2 is right
A block slides down an inclined plane of slope angle (alpha) with constant velocity. It is then projected up the same plane with an initial speed V0. How far up the incline will it move before coming to rest?Will it slide down again?
F=ma
What I did:Y coordinate
-mg * Cos(alpha)+N=ma(y)=0
X coordinate
ma(x)=-F(friction)+mgSin(alpha)
F(fric)=mgsin(alpha)
WHEN BLOCK SLIDES UP
mgsin(alpha)+F(gravity)=ma(x)
2mgsin(alpha)=ma(x)
a(x)=2gSin(alpha)
S=-V^2/(4gsin(alpha))
What my friend did:
F(fric)=N * μ = mg * cos(α) * μ
F(fric)=mg* sin(α)=mg* cos(α)* μ
μ = tg(α)
S=V0t -0.5at^2
a=μ * mg * sin(α)
t=V0/a
S=V0^2/a -V0^2/(2a),
where a= sin^2(α)/cos(α) * mgOh and I don't really know whether it will slide down or not, I hope you guys can help me!
Thanks in advance.
Your distance formula looks right but I figured acceleration, a = 2gsinα
You need to know that for a body on a ramp that static friction is greater then kinetic friction. At the instant the moving body stops evaluate the forces on the body and remember the static friction is greater then the kinetic friction.
wuffle said:
a=μ * mg * sin(α)
I do not think the above are correct since the component of the weight is also contributing to the retardation up the plane.
