How Can You Solve for A and B Using Points (4,1) and (-5,-3)?
  • Thread starter Thread starter lvlastermind
To solve for integers A and B using the points (4,1) and (-5,-3) in the equation Ax + By = 7, two equations are derived: 4A + B = 7 and -5A - 3B = 7. These equations can be solved using methods such as substitution or elimination. The suggestion to use a matrix and row reduction is also mentioned as a viable approach. The discussion emphasizes that with two equations and two unknowns, the problem is straightforward. Understanding the concepts from a linear algebra textbook can aid in finding the solution.
lvlastermind
Find integers A and B such that (4,1) and (-5,-3) are solitions to Ax + By = 7
Plug them into x and y to get:
4A + B = 7
and
-5A + -3B = 7
And solve :smile:
try putting the coefficients and answers into a matrix and Row reduce...
oh... sorry, just finished a semester in Linear Algebra :-)
but really... you have 2 equations that are equal to each other ad 2 unknowns... that is easy to solve just read the math book you have (I know, I know who reads a math book :-D )
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
