Mastering Vector Direction: Tips and Tricks for Understanding Degrees
  • Thread starter Thread starter superdude
    Vectors
Vector directions correspond to specific degrees on a compass: due north is 0 degrees, due east is 90 degrees, due south is 180 degrees, and due west is 270 degrees. The discussion clarifies that north is not 90 degrees, but rather 0 degrees, with east being the next clockwise direction. This understanding is essential for accurately interpreting vector directions in various applications. The clarification helps users align their knowledge of vectors with standard navigational conventions. Mastering these degrees is crucial for effective vector analysis.
superdude
Hello:
I don't have a question on how to solve a specific problem, rather vectors in general.
In my book, they often give vector direction by stating "due north", "due east", "due west", "due south". However, I can't figure out which of these directions correspond with what degree. For example, is "due north" = 90 degrees?
Please help.
Thanks
I 10 years of using vectors I have always had 90 degress = north.
so what are the degrees of the other diretions? east, south, west?
West = 180 Degrees
South = 270 Degress
East = 0 Degrees
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
