Need to calculate work from mass and two velocities
  • Thread starter Thread starter kylepetten
    Mass Work
To calculate the work done when a 1150 kg car accelerates from 2 m/s to 6 m/s, the change in kinetic energy (KE) is used. The formula for work done is Work = 0.5 * mass * (final velocity^2 - initial velocity^2). Applying the values, Work = 0.5 * 1150 * (6^2 - 2^2) results in the total work done. The initial confusion about insufficient information was resolved with this calculation approach. Understanding the relationship between work and kinetic energy is crucial for solving similar problems.
kylepetten
Calculate how much work is done when a 1150 kg car accelerates from 2 m/s to 6m/s
I have no idea. It seems like insufficient information to me. Please help! I am in great need as my exam is drawing near!
Thanks!
Thanks!
Work done=change in KE=0.5*1150(6^2-3^2)
oh, man, i sure was thinking too hard. thank you very very much! well appreciated!
I was thinking using 2 purple mattress samples, and taping them together, I do want other ideas though, the main guidelines are; Must have a volume LESS than 1600 cubic centimeters, and CAN'T exceed 25 cm in ANY direction. Must be LESS than 1 kg. NO parachutes. NO glue or Tape can touch the egg. MUST be able to take egg out in less than 1 minute. Grade A large eggs will be used.
