Why isn't 80 mod (-11) equal to 3?
  • Thread starter Thread starter Arixal
    Negative
Arixal
Can someone please explain why 80 mod (-11) is -8…? Why isn’t it 3?
b = aq + r
80 = (-11)q + r
80 = (-11)(-7) + 3
Thus 80 mod (-11) = 3..
b = aq + r
80 = (-11)q + r
80 = (-11)(-7) + 3
Your calculation is correct.
-8 and 3 are equivalent mod -11. Both answers are right.
Yes, they are the same, but typically a mathematical function with multiple 'valid' values is assigned a standard value by convention. Thus, the √ function is defined to be the non-negative root; arcsin etc. also have standard ranges.
In number theory, the non-negative value is taken for the mod function regardless of the signs of the arguments. Programming languages are annoyingly inconsistent. See http://en.wikipedia.org/wiki/Modulo_operation#Remainder_calculation_for_the_modulo_operation.
There are a number of different ways of thinking about "modulo". The most fundamental uses "equivalence" classes. -8 and 3 are in the same equivalence class "modulo 11" because -8= (-1)11+ 3 or, alternatively, 3+ 8= 11= 0 (mod 11) so that 3 is the additive inverse of 8: -8= 3 (mod 11).
It is a common convention to use the smallest positive number in an equivalence class to "represent" the class but any number in the class can be used. Sometimes it is convenient to use "-8" rather than "3" just as sometimes it is convenient to use 2/4 rather than 1/2.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
