Nested sequence of closed sets and convergence in a topological space.
The discussion revolves around a problem in topology concerning a nested sequence of closed sets in a topological space. The original poster presents a scenario where a sequence of closed subsets \(A_1 \supseteq A_2 \supseteq A_3 \ldots\) contains points \(a_i\) converging to a point \(b\), and the task is to prove that \(b\) belongs to the intersection of all \(A_i\).
  • Conceptual clarification, Assumption checking, Problem interpretation
  • Participants explore the implications of assuming \(b \not\in \cap A_i\) and question the validity of the original proof attempt. Some suggest that the closed nature of the sets implies that limit points must be contained within the sets, while others raise concerns about the assumptions made regarding the equality of the sets.
The discussion is ongoing, with participants providing insights and questioning the assumptions made in the original proof. There is a recognition of the need for clarity regarding the relationships between the sets and the point \(b\). Some participants suggest alternative approaches to demonstrate the required inclusion of \(b\) in the intersection.
Participants note that the hypothesis allows for the possibility that some \(A_n\) may equal \(A_1\), which complicates the proof. There is also mention of the need for a proper subset relationship to establish certain conclusions about neighborhoods and limit points.
Artusartos
Let ##X## be a topological space. Let ##A_1 \supseteq A_2 \supseteq A_3...## be a sequence of closed subsets of ##X##. Suppose that ##a_i \in Ai## for all ##i## and that ##a_i \rightarrow b##. Prove that ##b \in \cap A_i##.
Suppose, for contradiction, that ##b \not\in \cap A_i##. Then there exists ##n \in \Bbb{N}## with ##b \not\in A_n##. But then ##b \not\in A_i## for all ##i \geq n##.
Since ##A_n## is closed, we can pick an open neighborhood ##V## of ##b \in A_1## with ##V \cap A_n = \emptyset##. By the definition of convergence, ##V## needs to contain all ##a_i## with ##i \geq N## for some ##N##. This is not possible because only a finite number of the ##a_i## can be contained ##V##, since ##b \not\in A_i## for all ##i \geq n##.
Is my answer correct?
Thanks in advance
This is false. The hypotheses allow successive subsets to be equal, so it may be that A_n = A_1 for some n > 1.
The way to show that b \in \bigcap A_n is to show that b \in A_n for each n \in \mathbb{N}.
You know that A_n is closed, so it contains all its limit points. Does there exist a sequence lying within A_n whose limit is b?
If ##A_n = A_1## for any ##n>1##, then we automatically get a contradiction, because ##a_i \rightarrow b## implies that ##b## is in the closure of ##A_1##. However, ##\bar{A_1} = A_1## and ##b \not\in A_1##. A contradiction, right?
In order for your proof to work, you need there to exist some A_n which is a proper subset of A_1. If, by assumption, b \notin A_n, then it can only be because A_n is such a proper subset, and there then exists an open neighbourhood V of b such that V \cap A_n = \varnothing.
The only circumstance in which you can't do this is when A_n = A_1 for all n \in \mathbb{N}, in which case trivially b \in A_1 = \cap A_n.
Your proof just needs to be explicit about these points.
My other point is that there is a simpler direct proof which doesn't have this difficulty: for each n \in \mathbb{N}, the subsequence \{a_n, a_{n+1}, \dots\}\subset A_n has limit b.
Two comments:
1. What do you mean by "an open neighborhood ##V## of ##b \in A_1##"? Are you claiming that ##b \in A_1##? On what basis? And why does your proof need this to be true anyway?
2. If ##b \not\in A_n##, then ##b \in A_n^c##. Since ##A_n## is closed, ##A_n^c## is an open neighborhood of ##b##. You don't need to introduce a new set ##V##. If ##i \geq n##, can ##a_i## be in ##A_n^c##?
