Solution??
paytona said:
There are 4 charges in the corner of a square with the lengths of the sides measuring 18.2cm
q1= 2.34μC (top left) q2=-1.58μC (top right) q3= 2.03μC (bottom left) q4= -3.00μC (bottom right)
→Calculate net force on q4
→Calculate net force at the center of the square
Fnet=|KQ|/r^2
K constant = 8.99x10^9
q1= [(8.99x10^9)(2.34x10^-6)]/(0.182)^2 = 635086.3422 @ 315°
q2= [(8.99x10^9)(1.58x10^-6)]/(0.182)^2 = 428818.9832 @270°
q3= [(8.99x10^9)(2.03x10^-6)]/(0.182)^2 = 550950.9721 @ 0°
for my next step I was going to calculate x and y components and then plug it into the
d=*sqrt [(x^2)+(y^2)]
to calculate net force on q4... but I'm very uncertain about how to continue or if my previous calculations are even right.
Ok so this is what I did
→ Using pythagoreon theorem I found the length of the diagonal line toward q4 which = 025738684 m
I applied this to the previous calculation that I did wrong. But also, wouldn't the angle of q2 be 90° because it is a negative force and therefore repels away from the negative force of q4?
Anyway this is what I did
q1= [(8.99x10^9)(2.34x10^-6)]/(0.25738684)^2 = 317543.2411 @ 315°
q2= [(8.99x10^9)(1.58x10^-6)]/(0.182)^2 = 428818.9832 @90°
X and Y components:
E1 -- x: 224536.9791 y: -224536.9791
E2 -- x: 0 y: 428818.9832
E3 -- x: 55090.9721 y: 0
I then added the x components and the y components to calculate E4
x: 775487.9512 y: 204282.0041
I then used the distance formula to calculate the net field on E4:
FnetE4: *sqrt [(775487.9512^2)+(204282.0041^2)]
FnetE4: 801943.0776C ?
Do I still need to calculate the angle?
I did but it doesn't seem right.
Angle tan -1:y/x
=204282.0041/775487.9512
=14.8°
