Net torque Need help with angular acceleration.
The discussion centers on calculating the net torque for a wheel with a rotational inertia of 12 kg m², which experiences an angular velocity change from 5.0 rad/s to 6.0 rad/s over 5.0 revolutions. The key equations utilized include the relationship between angular acceleration and net torque, specifically: Net torque = (angular acceleration) * (rotational inertia). The solution involves using the equation (wf)² - (w0)² = 2 * alpha * omega to find angular acceleration, which is essential for determining the net torque.
  • Understanding of rotational inertia and its units (kg m²)
  • Familiarity with angular velocity and its measurement (rad/s)
  • Knowledge of angular acceleration and its calculation
  • Proficiency in using kinematic equations for rotational motion
  • Study the derivation and application of the equation (wf)² - (w0)² = 2 * alpha * omega
  • Learn about the relationship between torque, angular acceleration, and rotational inertia
  • Explore the concept of rotational kinematics in greater detail
  • Investigate practical applications of torque in mechanical systems
Students in physics or engineering courses, particularly those focusing on dynamics and rotational motion, as well as educators seeking to enhance their teaching of torque and angular acceleration concepts.
zelli
A certain wheel has a rotational inertia of 12 kg m2. As it turns through 5.0 rev its angular velocity increases from 5.0 rad/s to 6.0 rad/s. If the net torque is constant, its value is:
Angular acceleration = dW/dT
Net torque = (angular acceleration)*(rotational inertia)
Θf = Θi + (Wi)(dT) + [tex]\frac{1}{2}[/tex] [tex]\alpha[/tex][tex]\Delta[/tex]t2
I have dW = 5-6=-1rad/s
I am confused on how to find dT. The equations have have both have two unknowns (t & [tex]\alpha[/tex])
why don't you try this formula:
(wf)^2 - (w0)^2 = 2 alpha * omega.
Thank you so much! That worked. I'm glad you had that equation. I did not, and it happened to be on the test.
  • · Replies 30 ·
  • · Replies 22 ·
