What is the net impulse and average force on a ball caught in hand?
The net impulse exerted on a ball of mass 1.5 kg traveling downward at 10 m/s and coming to rest in 0.25 seconds is calculated to be 15 kg m/s. The average force exerted by the hand on the ball must account for gravitational force, which adds to the total force needed to stop the ball. The gravitational force acting on the ball is 14.7 N (1.5 kg multiplied by 9.8 m/s²). The hand must exert a force greater than 60 N to counteract both the gravitational force and to bring the ball to rest. Understanding the relationship between impulse and gravitational force is crucial for accurate calculations.
snoopygal327
A ball of mass 1.5 kg is traveling downward at a speed of 10 m/s. It comes to rest in your hand in .25 s. What is the net impulse exerted on the ball? What is the average force exerted by the hand on the ball (Don't forget the gravitational force.)
J = mvf-mvi
J = F\Deltat
I figured out that the impulse is 15 kg m/s from the first equation. I thought that I had figured out the force exerted by the hand on the ball to be 60 N but now I'm not sure what it means by gravitational force. How does this affect the force exerted by the hand on the ball?
J = mvf-mvi
J = F\Deltat
Over that time period that you used you also had gravity in the form of m*g acting on the hand as well.
For instance if you had merely arrested its acceleration at the point that it contacted your hand and it traveled still at 10m/s with your hand then your hand would have been exerting a force of m*g on it to keep it from accelerating further. Not only did you do that, but you also arrested its motion all together which is the impulse force you calculated.
I have to calculate another impulse for the gravitational force? So it would be something like J = (1.5 kg)(9.8 m/s2)(.25s).
No. It's just that the gravitational force was constant throughout the impulse and hence is added to the average force.
Oh I see. Thank you.
No problem.
Cheers.
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
