Newbie Physics Help: Vector Addition & Subtraction
  • Thread starter Thread starter I am a Newbie
The discussion focuses on vector addition and subtraction, specifically for vectors A=4i -3j and B=-1i -5j. The user successfully calculated A+B as 3i - 8j and A-B as 5i + 2j but struggled with finding the magnitudes |A+B| and |A-B|. Clarifications were provided that the absolute value refers to the magnitude of the resultant vectors, which can be calculated using the Pythagorean theorem. The correct approach involves finding the lengths of the resultant vectors from their components, leading to the final answers for the magnitudes. Understanding that magnitude is a scalar quantity distinct from vector components is crucial for solving these problems.
I am a Newbie
First, let me say I am new to the forums and new to physics, so if I do something wrong I apologize.
Consider the 2 vectors
A=4i -3j and B = -1i - 5j
a) Calculate A +B
b) Calculate A-B
c) Calculate |A+B|
d) Calculate |A-B|
I easily determined a and b, however c and d are giving me dificulty since I don't exactly know how the absolute value affects the vectors. Any help would be much appreciated - Newb
It means that you turn the vectors into positive values and add or subtract the value of the magnitude stick, which I can't remember the name of.
I was wrong. I didn't check the notation properly. c and d are finding the absolute value of the difference between the vectors. So just subtract / add them normally, and find the hypotenuse of the resultant triangle.
In this case, the bars mean the length of the vector inside. So for c), the problem is asking for the length of the vector that is the vector sum of A and B. For b), the problem is asking for the length of the vector that is the vector difference of A and B.
Does this help?
Still confused..lol,
a) 3i + -8j
b) 5i +2j
That part I get
is this how to do it?(just like you would use a normal abs value?)
c) |4i+-1i|=|3i| and |-3j+-5j|=|-8j|= 8j
making the FINAL answer 3i+8j
and if that is correct is
d) |4i--1i|=|5i| and |-3j--5j|=|2j|
making that FINAL answer 5i+2j
is this right?
C and D are asking for the resultant magnitude of the vectors, so that means that you take those x and y components, and then calculate the hypotenuse of the triangle that they form. Pythagorean theorem, just do this ((I + I)^2 + (J + J)^2)^(1/2) that that is the answer to C. Magnitude is a scalar, while all of the components are vectors.
Thread 'Trying to understand the logic behind adding vectors with an angle between them'
My initial calculation was to subtract V1 from V2 to show that from the perspective of the second aircraft the first one is -300km/h. So i checked with ChatGPT and it said I cant just subtract them because I have an angle between them. So I dont understand the reasoning of it. Like why should a velocity be dependent on an angle? I was thinking about how it would look like if the planes where parallel to each other, and then how it look like if one is turning away and I dont see it. Since...
