Newton's 3rd law and its affect
  • Thread starter Thread starter icecomet
    Law
In a bike crash against a metal fence, both the bike and the fence exert equal and opposite forces on each other, as stated by Newton's 3rd law. However, the difference in mass and material properties leads to different responses; the bike, being more massive, may not deform significantly, while the fence can bend due to its structural limitations. The discussion highlights that the ability of materials to withstand force varies, affecting how they respond during collisions. Additionally, the forces act on different bodies, which is crucial in understanding the resulting damage. The interaction illustrates the complexities of force application in real-world scenarios.
icecomet
When a bike crashes into a metal fence why does the fence bend when the magnitude of the forces that they exert upon each other are the same?
FAB = -FAB
I think this is becuase the bike has more mass than the fence... but i am not sure how this is applied.
no f=ma so the mass is already accounted for, should certain materials or apparatuses be able to withstand more force than others?
and you also have to remember that the opposite forces work on different bodies
