Newton's Laws, Force and Kinematics
A particle traveling at a constant speed of 24.5 m/s is stopped by a force of 14.3 N over a distance of 52.9 m. The time taken to stop is calculated as 4.318 seconds, with an acceleration of 5.673 m/s². The initial attempt to find mass using F=ma led to an incorrect result due to a calculation error, which was later corrected. An alternative method to find mass involves using the work-energy theorem, relating work done to changes in energy. The discussion emphasizes the importance of careful calculations in physics problems.
skydiver
A particle is traveling in a straight line at a constant speed of 24.5 m/s. Suddenly, a constant force of 14.3 N acts on it, bringing it to a stop in a distance of 52.9 m.
a. Determine the time it takes for the particle to come to a stop.
b. What is its mass?
1. vx2 = v0x2 +2a\Deltax
2. \Deltax = v0t + 0.5at2
3. F=ma
I know how to solve part a. I use equation 1 to find a which is 5.673 m/s^2
I use that value of a in equation 2 to find t which is 4.318 s
This is all correct.
I am having trouble with part b - to find mass.
The only equation I have to find mass is f=ma
F is 14.3N given, a as calculated is 4.318 which gives m as 3.311 kgs which is incorrect.
The correct answer is 2.52 kg
So I thought that for F=ma, F must be the resultant force of some sort.
So I subtracted 24.5-14.3 (which I am sure is not a correct step to do) gives me 10.2
And that divided by a (4.318) gives me m as 2.362 which is close but not correct.
Any other thoughts? Thanks so muchEDIT: Aarggghh.. stupid me
I am diving by t (4.318) instead of the a I found (5.673).
Can't believe I spent so much time on this stupid stupid mistake.
Welcome to PF!
Hi skydiver! Welcome to PF! :smile:
I'm glad you've sorted it out! :biggrin:
Just for the record, there's another way of finding the mass …
just calculate the work done and then use the work-energy theorem … work done = change in energy. :wink:
The really beautiful thing is, that the first equation he posted:
v_f^2=v_0^2+2ad is completely equivalent.
Multiplying by a factor of \tfrac{1}{2} m provides:
\tfrac{1}{2} mv_f^2=\tfrac{1}{2} mv_0^2+Fd
(The dot operator is included in the way the equation is defined, since the a term refers to the acceleration in the direction of the distance traveled.)
