Examples of Newton's Laws of Motion in Practice
In summary, Newton's laws of motion state that objects will stay in motion or change speed based on the forces acting upon them.
pavadrin
156
hey,
i was wondering if somebody out there may be able to give me examples of Newton's Laws of motion in practise so that I would be able to grasp the concept of the these laws
thanks for your time,
Pavadrin
What do you mean "in practice"? Everything moves according to newtins laws of motion.
A simple example, you drop a rock from the height of 10m, at what speed does it hit the ground? So if you can firgure out the Force on the rock (mg) theb you can get the Acceleration (F = ma , 2nd law) and with that you can calculate the time that it takes to get to the ground and the speed that it's goin after that time.
In basiclly all questions regarding Newtons laws of motion you work in that order - calculate forces, then acceleration, then speed time and distance depending on the information. Sort of vague question though.
Law the First:
An object at rest tends to stay at rest and an object in motion tends to stay in motion with the same speed and in the same direction unless acted upon by an unbalanced force.
This means that, to change an object's velocity (or lack thereof) a net force needs to act on it. This happens...anywhere, really. Your chair stays where it is because the gravitational force is negated by the reactionary force of the floor (see third law). An aircraft gets continually faster as it's taking off because the thrust from the engines is larger than the drag caused by the air (until it reaches cruise, anyway). Basically - if the forces on an object don't completely cancel each other out, the object will accelerate.
Law the Second:
The acceleration of an object is dependent upon two variables – the net force acting upon the object and the mass of the object.
F = ma, as the poster above me stated. Going back to the aircraft example, a piston engine on a Cessna can accelerate the aircraft at a certain rate, reaching some velocity after a certain amount of time. If you tried to use that same engine and propeller on a 747, it would take much, much longer to reach that same velocity (ignoring drag, friction etc).
Law the Third:
For every action, there is an equal and opposite reaction.
Basically, when two objects interact, an equal and opposite force acts upon each of them. Take the chair example from earlier - your chair is exerting a force on the floor. To stop that chair from just going straight through the floor, the floor exerts a reactionary force back on the chair which is equal in magnitude but opposite in direction, creating (in this case) a net zero force. A bird pushes on the air in flight, pushing the air backwards, but the air also exerts a force on the bird's wing, pushing the bird forwards.
Does that help at all?
(BTW, credit should be given to http://www.physicsclassroom.com/Class/newtlaws/newtltoc.html" for the definitions. It goes into each of these laws in much more detail and was found on a Google search of "Newton's laws", amazingly enough. That crazy internet can do anything these days!)
thanks Hawknc, that's an awsome post :smile: :smile:
1. What are Newton's Laws of Motion?
Newton's Laws of Motion are a set of three fundamental principles that explain the behavior of objects in motion. They were developed by Sir Isaac Newton in the 17th century and are still widely used in modern physics.
2. What is Newton's First Law of Motion?
Newton's First Law of Motion, also known as the Law of Inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
3. What is Newton's Second Law of Motion?
Newton's Second Law of Motion states that the acceleration of an object is directly proportional to the net force acting on it and inversely proportional to its mass. This means that the greater the force applied to an object, the greater its acceleration will be, and the more massive an object is, the less it will accelerate.
4. What is Newton's Third Law of Motion?
Newton's Third Law of Motion states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
5. How do Newton's Laws of Motion apply to real-life situations?
Newton's Laws of Motion have a wide range of applications in everyday life, from sports to transportation to space travel. For example, the first law explains why objects stay in motion (like a ball rolling across the ground) until acted upon by a force (like friction). The second law helps us understand how cars accelerate and decelerate, and the third law is essential for rocket propulsion and the movement of animals and humans.
