Newton's Laws Problem- Question on upcoming TEST
A block on a frictionless 30-degree ramp slides down and falls 1.0 m to land in a hole located 1.0 m from the ramp's end. The problem involves calculating the initial height from which the block should be released, considering both x and y components of motion. The time to fall and the required x-velocity were initially calculated, but the presence of an initial y-velocity at the ramp's end complicated the solution. After deriving the necessary equations, the final ramp speed was determined to be 3.9319 m/s, leading to a required height of approximately 0.78875 m on the ramp. This problem exemplifies the application of Newton's laws and kinematics in projectile motion.
mrmiggidude
Newton's Laws Problem- Question on upcoming TEST!
A small block is placed at height h on a frictionless 30 degree ramp. Upon being released, the block slides down the ramp then falls 1.0 m to the floor. A small hole is located 1.0 m from the end of the ramp. From what height h should the block be released in order to land in the hole?
Newton's Laws
Kinematics Equations
I did the problem assuming there would be no initial Y-velocity.
And figured out the time it would take for the object to fall to the ground after leaving the ramp, and the X-velocity it would need to get to the whole.
The time was .45 seconds and the X-velocity was 2.21 m/s.
With that it should be really easy to find the time to get to that velocity, and then the height needed to start from...
But I realized there would be an initial velocity in the y direction when it reaches the end of the ramp. I've spent nearly 3 hours trying to solve this problem, and it might be on an upcoming test. I have tried the problem with different axis, and I just can not figure it out. Please help, my test is this week!
After leaving the plane, the block will have an unknown speed (S), which can be broken into x,y components. The x,y kinematics are:
x - 1
x0 - 0
V - ?
V0 - Scos(-30)
a - 0
t - t
y - 0
y0 - 1
V - ?
V0 - Ssin(-30)
a - -9.8
t - t
(note: time will be the same in both)
In both cases, V is what we don't care about. We then use x=x0+v0t+.5at2
in the x case:
1=0+Scos(-30)+.5(0)t2
Solving for t gives t=1/Scos(-30)
in the y case, with t-substitution:
0=1+Ssin(-30)*1/Scos(-30)+.5(-9.8)(1/Scos(-30))2
In the middle velocity term, S cancels out. Multiplying all known numbers as well as squaring the third term gives:
0=1-.5774-6.5333/S2
Solving for S gives S = 3.9319 m/s
Now with a target final ramp speed, we can set up a 3rd kinematics equation for the slide. The acceleration will be modified from gravity: Slide force = 9.8*sin(30) = 4.9 m/s2.
x - ?
x0 - 0
V - 3.9319
V0 - 0
a - 4.9
t - ?
We don't care about time in this one, so the equation we use is V2 = V02+2a(x-x0).
3.93192=0+2*4.9*(x-0)
Solving for x gives x=1.5775 m up the ramp. They said they wanted height and not ramp distance, so we find the y component of the ramp length: 1.5775*sin(30) = .78875 m 'high' on the ramp.
Brutal!
Yes! That was totally it. Brutal problem, indeed!
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanged mass'
