Designing an Elevator for a Hospital: Maximum Speed and Newton's Laws Explained
  • Thread starter Thread starter physstudent1
    Laws Newton's laws
The discussion focuses on designing a hospital elevator with a maximum force of 1.6 times a passenger's weight and an upward acceleration over a distance of 3 meters. The initial calculations led to a misunderstanding of acceleration versus maximum speed, with a participant calculating a net acceleration of 5.9 m/s². However, to find the maximum speed, kinematic equations should be applied, considering the initial velocity is zero. The final answer for the maximum speed of the elevator is confirmed to be 5.9 m/s. The conversation highlights the importance of correctly applying physics principles in engineering design.
physstudent1
"You are designing an elevator for a hospital. The force exerted on a passenger by the floor of the elevator is not to exceed 1.6 times the passenger's weight. The elevator accelerates upward with constant acceleration for a distance of 3m and then slows down. What is the maximum speed of the elevator?"
The answer in the back of the book is 5.9 m/s.
When I drew a FBD and solved for acceleration I came up with 5.9 though. I made my equation 1.6mg - mg = ma. Then I canceled m out of everything and got a to be 5.9 m/s^2 what did I do wrong? Obviously this cannot be the acceleration if the max speed is this.
Excellent work so far, but you need to finish the problem. You have calculated the net acceleration acting on the elevator. From the problem, we see the elevator undergoes constant accleration through a displacement of 3m. Kinematically, is there an equation that we can use that gives the final velocity in terms of the initial velocity (zero), acceleration, and displacement?
yeah.
Oh I see thanks alot:)
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
Thread 'A bead-mass oscillatory system problem'
I can't figure out how to find the velocity of the particle at 37 degrees. Basically the bead moves with velocity towards right let's call it v1. The particle moves with some velocity v2. In frame of the bead, the particle is performing circular motion. So v of particle wrt bead would be perpendicular to the string. But how would I find the velocity of particle in ground frame? I tried using vectors to figure it out and the angle is coming out to be extremely long. One equation is by work...
