How to Use Newton's Method for Computing 1/\sqrt{a} for a Simple Processor
Scootertaj
The most commonly used algorithm for computing \sqrt{a} is the recursion xn+1 = 1/2 (xn + a/xn), easily derived by means of Newton's method. Assume that we have available to us a very simple processor which only supports addition, subtraction, multiplication, and halving (a subtraction of one in the exponent), but not a general divide operation. Devise a Newton-based algorithm for this processor to compute 1/\sqrt{a} (it then only remains to multiply by a to get \sqrt{a}.
xn+1 = xn - f(xn)/f'(xn)
I found something that says the following:
Essentially try to compute a single reciprocal A = 1/a and
then solve f(x) = 1/x^2 - A = 0 (whose solution is x = sqrt(a))
iteratively using Newton's method:
xn+1 = (xn) (3 - A (xn)^2) / 2
I can see how this gets rid of the division, and we can account for the halving by subtracting one in the exponent, but how does this solve for 1/\sqrt{a} ?
Moreover, how do they get to the equation?
Skip finding the single reciprocal. Just use Newton's method to solve f(x)=a-1/x^2. The solution to that is x=1/sqrt(a), yes?
Update: I figured out I believe... This is what I did:
xn+1 = xn - f(xn) / f'(xn) = xn - (1/xn2 - A)(-xn3/2) = xn - xn(-1/2 + Axn2) = xn(1+1/2-Axn2) = xn/2 * (3-Axn2).
Ahh, that would make it easier, I'll go with that! (afterall, it gives the same solution).
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
