Wind Turbine Noise Dependence on Temperature & Pressure
  • Thread starter Thread starter xujipampil
    Noise
The discussion centers on a bachelor's thesis exploring the relationship between wind turbine noise levels and environmental factors like temperature and pressure. The user has collected data on wind speed, air pressure, temperature, density, and sound levels at various distances from the turbine. They seek advice on how to analyze this data to determine the impact of air temperature on noise levels, specifically looking for relevant formulas. Suggestions include treating the problem as an inverse one, modeling the measurement process, and isolating the variables of interest. The conversation emphasizes the importance of experimental design for effective data analysis.
xujipampil
Hello :) I'm new to this forum, so excuse me for my straightforwardness ;)
I'm working on my bachelor work and i can't find a solution.
I'm writing about wind turbines' created noise dependence on temperature and pressure. So i came to this point, that i have measurements of wind speed, air pressure, temperature, density, sound level of wind turbine at different distances. What i need is to distinguish how air temperature affects noise level that wind turbine spreads. The good advice, formula or advice on the formula would be appreciated. I hope i expressed myself clearly about the subject. Thanks in advance.
For now i have some formulas that might come in handy:
E(t)=0,5*ρ*V3, as of ρ=P/R*T
I came across this one: P (ThermalNoise) = k*T*B, but it's measured in watts, as of i need db.
Welcome to PF;
"straightforwardness" is good ;)
I'd treat this as an inverse problem.
Model the measurement process and extract the statistics of the noise for the different conditions, trying to isolate the variable you are investigating. The details depend on your data-sets ... ideally you design the experiment to perform useful measurements.
Consider an extremely long and perfectly calibrated scale. A car with a mass of 1000 kg is placed on it, and the scale registers this weight accurately. Now, suppose the car begins to move, reaching very high speeds. Neglecting air resistance and rolling friction, if the car attains, for example, a velocity of 500 km/h, will the scale still indicate a weight corresponding to 1000 kg, or will the measured value decrease as a result of the motion? In a second scenario, imagine a person with a...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
