Are there any existing experiments for non-axial tensile testing?
The discussion focuses on the need for non-axial tensile testing of bolts to understand the effects of load applied at various angles. The original poster acknowledges the complexity due to the bolts being grouted and seeks existing experiments that specifically address this type of testing. They mention finding relevant studies for composite materials but note that these do not align with their requirements for larger-scale tests. References to historical experiments by Munse and Cox (1956) and Steeve and Wingate (2012) are provided, but further information on similar larger-scale tests is requested. The inquiry highlights a gap in available research for non-axial tensile testing of bolts.
Caznik
Hi guys,
So say I want to perform tensile tests on a bolt, but want to see what the effect of applying the load at various angles to the axis of the bolt would be. It's kindabutnotreally a shear test... I realize that if I had complete knowledge of the material properties of the bolt I could probably figure it out, but it's more complicated than that because the bolt is grouted.
Does anyone know if any kind of intentionally-misaligned tensile test experiment exists? I've found some for composite materials but they consider "non-axial" to mean that the fibres are aligned at an angle to the test axis and generally examine small samples.
Thanks.
Found some stuff on combined shear/tensile tests for the people of the far future who see this post:
Munse and (I love this name) Hugh Cox, 1956:
https://www.ideals.illinois.edu/bitstream/handle/2142/4323/engineeringexperv00000i00437.pdf?sequence=3
Steeve and Wingate (NASA), 2012:
http://ntrs.nasa.gov/archive/nasa/casi.ntrs.nasa.gov/20120003667.pdf
Any further info would be appreciated, especially larger-scale experiments.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
