Where Does the Normal Line Intersect the Parabola Again?
The discussion focuses on finding the second intersection point of the normal line to the parabola y = -4 - 3x + 4x^2 at the point (1, -3). The user calculated the slope of the tangent line as 5 and derived the normal line's equation as y = -1/5x - 14/5. They then set the normal line equal to the parabola to find the intersection points, identifying x = 1 and x = -3/10 as solutions. The corresponding y-coordinate for x = -3/10 was calculated as y = -137/50. The user seeks confirmation of their calculations and methodology, while a responder questions the necessity of deriving the tangent line.
volc
Here is what I found, look at the end to see what my question is:
At what point does the normal line to the graph of y= -4 - 3x + 4x^2 at (1, -3 ) intersect the parabola a second time?
So far I have tried to find the derivative of the parabola which is:
8x-3 (this corresponds to the slope of the tangent line). Therefore now I replaced x by 1 because of the point I am given. This gives:
8(1)-3 = 5
So that is the slope of the tangent line. Now to know the equation of this line I do:
y=5x+b , replace x and y by the point I am given and solve for b.
-3=5(1)+b
b=-8
Thus, the equation is: y=5x-8
The normal is perpendicular to the tangent at (1,-3) so I take the negative reciprocal of the slope to find the slope of the normal:
5 becomes -1/5 (reciprocal). And now I get y=-1/5+b for the normal. Replace x and y by the point (1,-3):
y=-1/5x+b
-3=-1/5x+b
-3=-1/5(1)+b
-14/5=b
The equation for the normal is: y=-1/5x-14/5
Now I want to find when this line and the parabola meet so:
-1/5x-14/5 = -4 - 3x + 4x^2
0 = -6/5 -14/5x + 4x^2
Using (-b+/-sqrt(b^2-4ac))/2a
x1 = 1
x2 = -3/10
x1 = 1 I already know because that is the point where the normal, the tangent, and the parabola intersect. And x2 = -3/10 is the other point where only the parabola and the normal intersect.
To find the y-coordinate of -3/10 I just insert it into the equation and get:
y=-1/5(-3/10)-14/5
y= -137/50
Thus the other point is: (-3/10,-137/50)
I would just like to know if the above calculations are correct and that I am doing the proper steps.
Thanks a lot,
Cedrick O'Shaughnessy
That all looks good. I'm just not sure why you found the equation for the tangent line, since it doesn't seem like you needed it.
