Normalization of 1D velocity boltzmann distribution
6 replies · 4K views · last reply
throneoo
Suppose the pdf is A*exp(-mv^2/2kT) , where A is the normalization constant.
To obtain A I would integrate the pdf over the all possible values of v. The question is, should the limits be (-infinity,infinity) or [0,infinity) ? It seems that only by choosing the former can I get the correct normalization, but if in essence this is derived from an energy distribution , why doesn't it run from 0 to infinity?
If I try to work out <v> or <v^2> of this distribution, should I use (-infinity,infinity) or [0,infinity) ? because I always use the latter when working with the standard 3D maxwell Boltzmann distribution (normalization, <v>, <v^2>)
The pdf should be integrated over all possible values of v.
It is important to understand the processes you use, not just remember to use them.
as far as i understand it, the function is derived from a distribution of speed, which starts from 0. But if i am to use it to find the distribution of velocity, I presume it is reasonable to start from -infinity.
What I would then be confused about is the following: In the derivation of the 3d speed distribution , the same 1d velocity normalization constant (from above) is raised to the power 3. Why is a velocity normalization constant used in a speed distribution ?
Consider:
In each linear degree of freedom, the velocity distribution function would be even - since there is an equal chance of going either way.
What is the difference when you try the derivation from velocity instead of speed?
Consider:
Simon Bridge said:
Consider:
If I start from linear speed distributions from the start, I would get a normalization constant that is twice as large as that for a velocity distribution. Thus the 3d speed distribution would have an extra factor of 8 compared to the standard one, which is derived from linear velocity distributions
OK - so that basically means that the area in ##(-\infty,\infty)## for the un-normalized speed-derived function is twice that for the un-normalized velocity distribution.
Does that makes sense considering what you are doing?
After normalization, the main difference will be that the probability of ##0<v<\infty## is 0.5 for one and 1 for the other.
