Notation related to quotient fields
fortissimo
Let f(x) = x6 + x3 + 1 in Z_2[x]. Show that f(x) is irreducible. Let E = Z_2[x]/(f(x)),
and let α denote the image of x in the quotient field. Show that E* = <α>.
I have solved the first part, but what does E* mean? I have seen the asterix in connection with dual spaces before, but I reckon it means something else here.
It would be nice if someone could give some directions...
Hi fortissimo! :smile:
I do not understand what you mean with the image of x in the quotient field.
But I do know that the star notation in algebra usually means the set without the zero-dividers.
Hope this helps.
Thanks!
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
